Zum Hauptinhalt wechseln
TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
Was du brauchst
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: Schritt 1, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: Schritt 1, Bild 2 von 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 2, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 2, Bild 2 von 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 3, Bild 1 von 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 3, Bild 2 von 2
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 4, Bild 1 von 3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 4, Bild 2 von 3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: Schritt 4, Bild 3 von 3
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Thanks for this. Great help in sorting out my laptop.
Jack - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 588
