Einleitung
This guide will walk you through the necessary steps for replacing the motherboard in your Toshiba Satelite E45W-C4200X.
The motherboard is arguably the most important component in the laptop. This printed circuit board contains all the main components that operate your computer.
Before using this guide, make sure to review the troubleshooting page oftentimes, the battery can be fixed without replacing it.
If possible, back up your computer to an external hard drive before this replacement. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the replacement.
Was du brauchst
Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
Disconnect the fan cord from the harness.
Remove the cooling fan and heat sink from the laptop.
Carefully peel off the tape holding the heat sink onto the cooling fan.
Remove the cooling fan from the heat sink.
Unplug the connection to the battery.
Remove the three screws from the metal bracket on the left side of the circuit board using a Phillips #1 screwdriver.
Remove the bracket.
Remove the two screws from the black plastic cover using a Phillips #1 screwdriver.
Remove the black plastic cover.
Using a Phillips #1 screwdriver, remove the remaining two screws holding the circuit board in place.
Carefully remove the motherboard from the device.
Ein Kommentar
Could you help me to know the values for this piece? My motherboard has burned it, and I could not find the schematic; I guess it is an inductor. But I'm just learning about this. I hope that you can help me.
Regards.
