Zum Hauptinhalt wechseln
TRS-80 Color Computer Fuse Replacement
Was du brauchst
  1. TRS-80 Color Computer Fuse Replacement, Outside Casing: Schritt 1, Bild 1 von 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Fuse Replacement: Schritt 2, Bild 1 von 2 TRS-80 Color Computer Fuse Replacement: Schritt 2, Bild 2 von 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Fuse Replacement, Keyboard: Schritt 3, Bild 1 von 2 TRS-80 Color Computer Fuse Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Fuse Replacement, Motherboard: Schritt 4, Bild 1 von 3 TRS-80 Color Computer Fuse Replacement, Motherboard: Schritt 4, Bild 2 von 3 TRS-80 Color Computer Fuse Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Fuse Replacement: Schritt 5, Bild 1 von 3 TRS-80 Color Computer Fuse Replacement: Schritt 5, Bild 2 von 3 TRS-80 Color Computer Fuse Replacement: Schritt 5, Bild 3 von 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Fuse Replacement, Fuse: Schritt 6, Bild 1 von 2 TRS-80 Color Computer Fuse Replacement, Fuse: Schritt 6, Bild 2 von 2
    • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
  7. TRS-80 Color Computer Fuse Replacement: Schritt 7, Bild 1 von 3 TRS-80 Color Computer Fuse Replacement: Schritt 7, Bild 2 von 3 TRS-80 Color Computer Fuse Replacement: Schritt 7, Bild 3 von 3
    • Remove the power cable jumpers from the power supply.
  8. TRS-80 Color Computer Fuse Replacement: Schritt 8, Bild 1 von 1
    • Gently peel back the protective film on the top of the transformer.
  9. TRS-80 Color Computer Fuse Replacement: Schritt 9, Bild 1 von 3 TRS-80 Color Computer Fuse Replacement: Schritt 9, Bild 2 von 3 TRS-80 Color Computer Fuse Replacement: Schritt 9, Bild 3 von 3
    • Locate the two points the fuse is soldered into the circuit board.
    • Using a soldering iron and soldering wick, desolder and remove the fuse.
    • Place the new fuse into the location of the old one, and solder it in place.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 11-24, Maness Winter 2011 Mitglied von Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 2,765
