Zum Hauptinhalt wechseln
Table setting
Was du brauchst
  1. Table setting, Accessing the menu: Schritt 1, Bild 1 von 3 Table setting, Accessing the menu: Schritt 1, Bild 2 von 3 Table setting, Accessing the menu: Schritt 1, Bild 3 von 3
    • With the machine on, go to the Quick Settings in the Home Menu.
    • Select the "Level Table" option.
    • Select "Home XYZ" so that the head goes to the starting position.
  2. Table setting, Adjustment positions: Schritt 2, Bild 1 von 2 Table setting, Adjustment positions: Schritt 2, Bild 2 von 2
    • The leveling should be performed on the 4 points of the table, as shown in the figure.
    • Select the "Set P1" option to level the table height at the first point.
  3. Table setting, Adjusting table height: Schritt 3, Bild 1 von 3 Table setting, Adjusting table height: Schritt 3, Bild 2 von 3 Table setting, Adjusting table height: Schritt 3, Bild 3 von 3
    • The nozzle should be slightly away from the glass (thickness of a sulphite sheet).
    • To bring the table closer to the nozzle, turn the rosette clockwise.
    • To move the table away from the spout, rotate the rosette counterclockwise.
  4. Table setting, Adjustment of other points: Schritt 4, Bild 1 von 3 Table setting, Adjustment of other points: Schritt 4, Bild 2 von 3 Table setting, Adjustment of other points: Schritt 4, Bild 3 von 3
    • Repeat the procedure for adjusting P1 for the other points.
Abschluss
Ready! Your table is level!
pt en
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 232
