Zum Hauptinhalt wechseln
Tablet Chuwe 10.1 Touch Screen Replacement
Was du brauchst
  1. Tablet Chuwe 10.1 Touch Screen Replacement, Touch Screen: Schritt 1, Bild 1 von 2 Tablet Chuwe 10.1 Touch Screen Replacement, Touch Screen: Schritt 1, Bild 2 von 2
    • We must use a plastic guitar pick or in the case that you do not have one, a plastic card can do us helpful (credit card)
  2. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 2, Bild 1 von 3 Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 2, Bild 2 von 3 Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 2, Bild 3 von 3
    • Slowly, insert the pick pressing it and swinging it along the perimeter of the tablet's body
  3. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 3, Bild 1 von 1
    • Carefully loosen with your fingers the back and place the tablet face down on a flat and clean surface tablet
  4. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 4, Bild 1 von 1
    • the speaker is screwed next to the touch chassis, we must release the screw and place it in a visible place, the speaker will remain with adhesive tape next to the battery
  5. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 5, Bild 1 von 1
    • With the help of the pua or the fingers, we must release the data FLEX from the connection, making a small upward pressure
  6. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 6, Bild 1 von 1
    • Careful! The FLEX cable that joins the front and rear camera, will be completely loose, we must place it in a clean place for later assembly.
  7. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 7, Bild 1 von 1
    • we will have a third FLEX on the motherboard, we must do the same method to press up on the connector until it is released, carefully these FLEX are easy to break.
  8. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 8, Bild 1 von 2 Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 8, Bild 2 von 2
    • now with the help of a Phillips screwdriver, we must release the three screws that hold the base plate of the touch screen chassis, and the sensor with positive and negative cables, we can help with the fingers in a smooth way.
  9. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 9, Bild 1 von 2 Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 9, Bild 2 von 2
    • carefully, we already have the loose base plate of the touch chassis, we look at the various grips that connect the touch screen with the LCD and with the tine and small balancing we are doing pressure to separate touch and LCD screen.
  10. Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 10, Bild 1 von 3 Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 10, Bild 2 von 3 Tablet Chuwe 10.1 Touch Screen Replacement: Schritt 10, Bild 3 von 3
    • Following these steps we have loosen our LCD screen and the carcass of the touch screen, now we must look for the reference number that appears on the FLEX cable of the touch screen so we can order a new one
Abschluss
In order to reassemble your device, follow these instructions in reverse order
15 weitere Nutzer:innen haben diese Anleitung absolviert.
es en
100%
Hier starten ›
Fran Ruiz
515 Reputation
1 Anleitung geschrieben
2 Kommentare
No mention of the adhesive needed to reattach the screen.
Jan - Antwort
garcias por la ayuda
jorge alejandro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 48
Insgesamt: 3,688
