Einleitung
Your device is equipped with a single battery that is capable of providing several hours of normal usage. Deterioration over time or using while on the charger can cause the battery life to decrease or even cause the device to be unusable without being on the charger. To fix this, you must replace the battery.
Was du brauchst
Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
Set the back cover aside.
Locate the red and black wires that connect the battery to the motherboard.
Carefully peel away the tape that keeps the wires secured to the back of the display screen.
Soften the old solder by heating it with the soldering tool, so that the wires can be removed with tweezers.
Heat up the battery with the iOpener Heat tool in order to soften the adhesive that keeps the battery in place.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
