Einleitung
Use this guide to replace the battery in the Tagital T9X.
Was du brauchst
With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
Eine weitere Person hat diese Anleitung absolviert.
