Zum Hauptinhalt wechseln
Tagital T9X Camera Replacement
Was du brauchst
  1. Tagital T9X Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Camera Replacement: Schritt 2, Bild 1 von 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Camera Replacement, Camera: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, carefully remove the cloth covering from the ribbon connector for the camera.
  4. Tagital T9X Camera Replacement: Schritt 4, Bild 1 von 1
    • Use the tip of the spudger or your fingernail to flip up the small flap on the ZIF connector.
    • Carefully remove the ribbon cable from the connector.
  5. Tagital T9X Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the camera from its position at the top of the tablet.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 152
