Einleitung
This guide will show you how to replace the screen of a Tagital T9X.
Was du brauchst
With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
Locate the 2 ZIF connectors.
Remove both ZIF connectors by lifting the flap on the connectors and carefully removing the ribbons.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
