Zum Hauptinhalt wechseln
Tagital T9X Speaker Replacement
Was du brauchst
  1. Tagital T9X Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Speaker Replacement: Schritt 2, Bild 1 von 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Detach speaker wires from motherboard.
    • The wires are fragile and may break off while handling them.
  4. Tagital T9X Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic spudger to remove speaker from the back panel.
Abschluss
Ein Kommentar
Hi. I need a replacement speaker for my tagital t9x. What part number should I look up?
Jerry - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 124
