Zum Hauptinhalt wechseln
Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018)
Was du brauchst
  1. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018), Taillight Bulb: Schritt 1, Bild 1 von 1
    • Open the trunk of your vehicle.
  2. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 2, Bild 1 von 1
    • Locate the fabric access cover.
    • The fabric access cover is located right behind the the taillight.
  3. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 3, Bild 1 von 1
    • Gently pull out the access panel.
  4. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 4, Bild 1 von 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 4, Bild 2 von 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 4, Bild 3 von 3
    • Start unscrewing the large plastic screw counter-clockwise.
  5. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 5, Bild 1 von 1
    • Place the screw in a safe spot.
  6. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 6, Bild 1 von 2 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 6, Bild 2 von 2
    • Remove the taillight assembly by gently wiggling it out with both hands.
  7. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 7, Bild 1 von 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 7, Bild 2 von 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 7, Bild 3 von 3
    • Unplug the taillight power plug by pinching both tabs to release the plug.
  8. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 8, Bild 1 von 1
    • Pinch the two release tabs towards each other and lift the bulb bracket out of the tail housing.
  9. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 9, Bild 1 von 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 9, Bild 2 von 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): Schritt 9, Bild 3 von 3
    • Gently turn the bulb counter-clockwise until you can pull it out.
    • Don't squeeze the bulb too hard as it could break.
Abschluss
Krystian Krys
169 Reputation
1 Anleitung geschrieben
York University, Team O-13, Woodhouse Winter 2023 Mitglied von York University, Team O-13, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG13
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 104
Letzte 30 Tage: 453
Insgesamt: 4,617
