Einleitung
Use this guide when you need to replace the battery because it has died.
Was du brauchst
Wedge a spudger in between the front and back panel.
Apply leverage downwards to the spudger in order to remove the back panel.
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
