Zum Hauptinhalt wechseln
Tapwave T2907US Zodiac 2 Directional Pad Replacement
Was du brauchst
  1. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 2, Bild 1 von 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Battery: Schritt 3, Bild 1 von 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Directional Pad Replacement, Directional Pad: Schritt 5, Bild 1 von 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 6, Bild 1 von 1
    • Pull off the black memory card slot piece.
  7. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 8, Bild 1 von 2 Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 8, Bild 2 von 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 9, Bild 1 von 1
    • Grasp the upper left edge of the motherboard and slide diagonally up and left away from the auxiliary port entrance.
    • Glue connecting the port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the 2 silver Philips #00 screws from both sides of the directional pad component on the front casing.
  11. Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 11, Bild 1 von 2 Tapwave T2907US Zodiac 2 Directional Pad Replacement: Schritt 11, Bild 2 von 2
    • Take out the 2 pieces of the directional pad with tweezers.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 10-33, Amido Winter 2012 Mitglied von Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 46
Insgesamt: 895
