Einleitung
When your ON/OFF switch fails, follow this guide to get your Portastudio operational.
Remove the power buton
Remove the screws from back
Gently open the device
Remove this screws
The PLAY doesn't work because the plastic is broken. It holds a spring.
Gluing the plastic will not work, as spring pressure is too high.
To make a good support for the spring, drill a hole on the metal and ADD a little screw.
Para remontagem de seu dispositivo, siga estas instruções na ordem inversa.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
