Zum Hauptinhalt wechseln
Tatung TAC-6G Heating Element Replacement
Was du brauchst
  1. Tatung TAC-6G Heating Element Replacement, Heating Element: Schritt 1, Bild 1 von 1
    • Lift the lid and bowl from top of the device
    • Be sure device is not plugged in before beginning replacement of heating element
  2. Tatung TAC-6G Heating Element Replacement: Schritt 2, Bild 1 von 1
    • Turn the bowl upside down so that the three legs point upwards
  3. Tatung TAC-6G Heating Element Replacement: Schritt 3, Bild 1 von 2 Tatung TAC-6G Heating Element Replacement: Schritt 3, Bild 2 von 2
    • Remove the one 7 mm Phillips screw from the side of the brass panel.
  4. Tatung TAC-6G Heating Element Replacement: Schritt 4, Bild 1 von 2 Tatung TAC-6G Heating Element Replacement: Schritt 4, Bild 2 von 2
    • Remove the 6mm Phillips screw that holds the stainless plate.
  5. Tatung TAC-6G Heating Element Replacement: Schritt 5, Bild 1 von 3 Tatung TAC-6G Heating Element Replacement: Schritt 5, Bild 2 von 3 Tatung TAC-6G Heating Element Replacement: Schritt 5, Bild 3 von 3
    • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
  6. Tatung TAC-6G Heating Element Replacement: Schritt 6, Bild 1 von 1
    • Using your hands, remove the heating plate that is on top of heating element.
  7. Tatung TAC-6G Heating Element Replacement: Schritt 7, Bild 1 von 1
    • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
  8. Tatung TAC-6G Heating Element Replacement: Schritt 8, Bild 1 von 1
    • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
  9. Tatung TAC-6G Heating Element Replacement: Schritt 9, Bild 1 von 1
    • Using, your hands, take out the heating element and replace it with a new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
6 Kommentare
where can I buy this heating element? Thanks.
dchang168 - Antwort
Tze Moh Yeo - Antwort
where to buy parts is the problem!!
William Co - Antwort
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 4,082
