Einleitung
The rice cooker contains a heating element responsible for heating and cooking the rice while it is turned on. In this guide we will show how to expose the heating element and replace it.
Was du brauchst
Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
6 Kommentare
where can I buy this heating element? Thanks.
where to buy parts is the problem!!
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
