Zum Hauptinhalt wechseln
Tatung TAC-6G Light Element Replacement
Was du brauchst
  1. Tatung TAC-6G Light Element Replacement, Light Element: Schritt 1, Bild 1 von 1
    • Start with the device standing upright.
  2. Tatung TAC-6G Light Element Replacement: Schritt 2, Bild 1 von 1
    • Remove the 11mm Phillips screw from below the power component panel.
  3. Tatung TAC-6G Light Element Replacement: Schritt 3, Bild 1 von 1
    • Pull the panel away from the rice cooker.
    • Remove the 9mm Phillips screw from behind the power component dashboard that is connected to the light plate.
  4. Tatung TAC-6G Light Element Replacement: Schritt 4, Bild 1 von 1
    • Pull the light plate from the power component panel.
  5. Tatung TAC-6G Light Element Replacement: Schritt 5, Bild 1 von 1
    • Flip the rice cooker device upside down.
  6. Tatung TAC-6G Light Element Replacement: Schritt 6, Bild 1 von 2 Tatung TAC-6G Light Element Replacement: Schritt 6, Bild 2 von 2
    • Remove the one 7mm Phillips screw from the side of the brass panel
    • Lift the brass plate off of the device and set it aside.
  7. Tatung TAC-6G Light Element Replacement: Schritt 7, Bild 1 von 1
    • Remove the 7mm Phillips screw holding the white and maroon colored wires that are connected to the heating element.
  8. Tatung TAC-6G Light Element Replacement: Schritt 8, Bild 1 von 1
    • Remove the 10mm Phillips screw that connects the white, blue and black wires to the white plastic piece in the corner of the device.
  9. Tatung TAC-6G Light Element Replacement: Schritt 9, Bild 1 von 1
    • Remove the 7mm Phillips screw that connects two white wires and one red wire to the heating "warm" switch.
  10. Tatung TAC-6G Light Element Replacement: Schritt 10, Bild 1 von 1
    • Using your hand, pull out the light plate with the maroon red and black wires.
  11. Tatung TAC-6G Light Element Replacement: Schritt 11, Bild 1 von 1
    • Replace the light plate dashboard.
Abschluss
Ein Kommentar
Reverse the steps for reassembly.
Tom Anderson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 631
