Einleitung
This device's power cord may break, so being able to easily replace it is important. This guide will teach you how to replace the rice cooker's power cord.
Was du brauchst
Remove the one 7mm Phillips Head #3 spanner screw from the side of the brass panel.
Remove the 7mm Phillips #3 brass screw that connects the white power cord wire and blue wire closest to the power cord.
Remove the 10mm Phillips #3 brass screw above the heating element that connects the white power cord wire and the maroon wire.
Using your hands, from the inside of the device, push the black plastic wire holder to release cords.
Pull the power cord through the hole, isolating the power cord from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Thanks! Ours wore out at the crimped part where the cable exits the rice cooker. After opening it up, we cut the cable ~6" from the loose end (not the plug end!), separated the two wire bundles, stripped part of the black plastic off (~1/5") slid the fiberglass sheaths over to the new bundles and attached w/o the circle metal ends by screwing it into the original place.
