Zum Hauptinhalt wechseln
Taylor Precision Product 3831S Kitchen Scale Battery Replacement
Was du brauchst
  1. Taylor Precision Product 3831S Kitchen Scale Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Taylor Precision Product 3831S Kitchen Scale Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Grab your scale and flip it over to get started.
    • Remove the small screw on the battery housing cover using the Phillips #00 screwdriver.
  2. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 2, Bild 1 von 2 Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 2, Bild 2 von 2
    • Next, push the tab in and remove the battery covering.
  3. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 3, Bild 1 von 3 Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 3, Bild 2 von 3 Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 3, Bild 3 von 3
    • Carefully remove the dead battery.
  4. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 4, Bild 1 von 1
    • With the indented side facing the scale, secure the new battery in the battery housing.
  5. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 5, Bild 1 von 1
    • Once the battery is secured, replace the battery cover.
  6. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 6, Bild 1 von 1
    • Using the Phillips #00 screwdriver once again, replace the screw that secures the covering.
  7. Taylor Precision Product 3831S Kitchen Scale Battery Replacement: Schritt 7, Bild 1 von 1
    • Now power on the scale.
Ziellinie
Arika Lewis
148 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 72
Insgesamt: 3,584
