Zum Hauptinhalt wechseln
Tea Kettle Switch Replacement
Was du brauchst
  1. Tea Kettle Switch Replacement, Switch: Schritt 1, Bild 1 von 3 Tea Kettle Switch Replacement, Switch: Schritt 1, Bild 2 von 3 Tea Kettle Switch Replacement, Switch: Schritt 1, Bild 3 von 3
    • Before you start, disconnect the device from its power source.
    • Remove the two bottom screws.
    • Remove the two top screws.
    • Remove the handle from the kettle.
  2. Tea Kettle Switch Replacement: Schritt 2, Bild 1 von 2 Tea Kettle Switch Replacement: Schritt 2, Bild 2 von 2
    • Pull out the switch.
    • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
  3. Tea Kettle Switch Replacement: Schritt 3, Bild 1 von 1
    • Click the replacement switch back into the handle part.
  4. Tea Kettle Switch Replacement: Schritt 4, Bild 1 von 1
    • Insert the light back into the switch.
    • This might take some extra attention, so be precise.
  5. Tea Kettle Switch Replacement: Schritt 5, Bild 1 von 1
    • Place the handle part back on the frame.
  6. Tea Kettle Switch Replacement: Schritt 6, Bild 1 von 1
    • Plug in the kettle.
    • Press down on the switch to check if it works again.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Antwort
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 31
Letzte 30 Tage: 128
Insgesamt: 25,196
