Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will help you replace your faulty volume knob. This guide should only be looked at after completing the Disassembly Guide.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the screws that are holding the circuit board in place. Remove the screws that are holding the circuit board in place.
    • Remove the screws that are holding the circuit board in place.
  2. Pull the circuit board out to reveal the inside of the display. Pull the circuit board out to reveal the inside of the display.
    • Pull the circuit board out to reveal the inside of the display.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Remove the screws and the black piece that are holding the volume control knob in place. Remove the screws and the black piece that are holding the volume control knob in place. Remove the screws and the black piece that are holding the volume control knob in place.
    • Remove the screws and the black piece that are holding the volume control knob in place.
  5. Pull the volume control knob from the outside and the white piece on the inside until they separate. Replace the volume knob with a new one to complete the repair.
    • Pull the volume control knob from the outside and the white piece on the inside until they separate.
    • Replace the volume knob with a new one to complete the repair.
Abschluss
To reassemble your device, follow these instructions in reverse order and follow the disassembly guide instructions in reverse order.
2 weitere Nutzer haben diese Anleitung absolviert.
Oliver Kunz
107 Reputation
1 Anleitung geschrieben
Cal Poly, Team 2-61, Propen Fall 2012 Mitglied von Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 3,608
