Zum Hauptinhalt wechseln
Technique - Test the Battery
Was du brauchst
  1. Technique - Test the Battery, Technique - Test the Battery: Schritt 1, Bild 1 von 3 Technique - Test the Battery, Technique - Test the Battery: Schritt 1, Bild 2 von 3 Technique - Test the Battery, Technique - Test the Battery: Schritt 1, Bild 3 von 3
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Technique - Test the Battery: Schritt 2, Bild 1 von 2 Technique - Test the Battery: Schritt 2, Bild 2 von 2
    • Remove the battery by lifting from slot on the right hand side.
  3. Technique - Test the Battery: Schritt 3, Bild 1 von 2 Technique - Test the Battery: Schritt 3, Bild 2 von 2
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Melinda Phan
438 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 9-64, Walters Spring 2011 Mitglied von Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Mitglieder
18 Anleitungen geschrieben
2 Kommentare
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Antwort
yes,not tablet with battery removal difficult
paulbeames7 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 40
Insgesamt: 10,169
