Zum Hauptinhalt wechseln
Teddy Bear Nose Replacement
Was du brauchst
  1. Teddy Bear Nose Replacement, Nose: Schritt 1, Bild 1 von 2 Teddy Bear Nose Replacement, Nose: Schritt 1, Bild 2 von 2
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: Schritt 2, Bild 1 von 2 Teddy Bear Nose Replacement: Schritt 2, Bild 2 von 2
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: Schritt 3, Bild 1 von 1
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: Schritt 4, Bild 1 von 2 Teddy Bear Nose Replacement: Schritt 4, Bild 2 von 2
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: Schritt 5, Bild 1 von 1
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: Schritt 6, Bild 1 von 1
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: Schritt 7, Bild 1 von 1
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: Schritt 8, Bild 1 von 1
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: Schritt 9, Bild 1 von 1
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: Schritt 10, Bild 1 von 3 Teddy Bear Nose Replacement: Schritt 10, Bild 2 von 3 Teddy Bear Nose Replacement: Schritt 10, Bild 3 von 3
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: Schritt 11, Bild 1 von 2 Teddy Bear Nose Replacement: Schritt 11, Bild 2 von 2
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Ziellinie
Nazib Khan
193 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 34
Letzte 30 Tage: 115
Insgesamt: 4,008
