Einleitung
Over time, a teddy bear’s nose can become worn down. It may fall out or even be chewed off by pets. This guide explains how to replace a teddy bear’s nose when it is damaged or missing. To complete this fix, you have to know how to hand-sew a whip stitch (How to Sew a Whip Stitch).
Was du brauchst
Flip the fabric of the snout inside out to expose the back of the plastic nose.
Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
Push the front of the new nose through the existing hole in the teddy bear’s face.
Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
