Zum Hauptinhalt wechseln
Teddy Bear String Smile Replacement
Was du brauchst
  1. Teddy Bear String Smile Replacement, String Smile: Schritt 1, Bild 1 von 1
    • Using the scissors, cut away the existing string smile from the teddy bear.
  2. Teddy Bear String Smile Replacement: Schritt 2, Bild 1 von 2 Teddy Bear String Smile Replacement: Schritt 2, Bild 2 von 2
    • Using a water-soluble marker, test a small patch on the teddy bear in the area you will be replacing the smile.
    • Once you have tested the patch and made sure the marker washes off the fabric, sketch the smile in the area you desire.
  3. Teddy Bear String Smile Replacement: Schritt 3, Bild 1 von 2 Teddy Bear String Smile Replacement: Schritt 3, Bild 2 von 2
    • Take one end of the thread and slide it through the thin hole, or eye, at the top of the needle.
    • Once the needle is threaded with your desired length of string (the length of the smile plus a bit more), tie both ends of the string together in a knot.
  4. Teddy Bear String Smile Replacement: Schritt 4, Bild 1 von 2 Teddy Bear String Smile Replacement: Schritt 4, Bild 2 von 2
    • At an angle, stick the needle through the back of the ear.
    • Pull the needle through a stitch-length away from the corner of your drawn on mouth.
    • Keep pulling until you feel the tug of the knot on the inside of the smile.
  5. Teddy Bear String Smile Replacement: Schritt 5, Bild 1 von 1
    • Stick the needle back through the hole you just made and pull it out a stitch-length away; this starts the backstitch.
    • You will be using the drawn on pattern as a reference.
  6. Teddy Bear String Smile Replacement: Schritt 6, Bild 1 von 1
    • Continue the backstitch across the smile area until the smile is complete.
  7. Teddy Bear String Smile Replacement: Schritt 7, Bild 1 von 3 Teddy Bear String Smile Replacement: Schritt 7, Bild 2 von 3 Teddy Bear String Smile Replacement: Schritt 7, Bild 3 von 3
    • Stick the needle through the second-to-last stitch.
    • Pull the needle through, diagonally, and pull it out behind the ear that you started with. This will leave a “tail” hanging from behind the ear.
  8. Teddy Bear String Smile Replacement: Schritt 8, Bild 1 von 3 Teddy Bear String Smile Replacement: Schritt 8, Bild 2 von 3 Teddy Bear String Smile Replacement: Schritt 8, Bild 3 von 3
    • At the longest part of the thread, cut the needle away.
    • Tie the two pieces of thread together into a knot against the back of the ear.
    • Cut away the remaining thread.
Abschluss
And now you’re all set! You get to enjoy more moments with your sentimental piece!
2 weitere Personen haben diese Anleitung absolviert.
Khadijah
214 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G17, Cardinal Summer 2020 Mitglied von UW Tacoma, Team S1-G17, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G17
1 Mitglied
Ein Kommentar
Please are you able to tell me the brand of this monkey? I’ve been searching for months for this as a replacement for my daughters lost monkey
Kirsty Thomas-Eardley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 23
Insgesamt: 1,379
