Zum Hauptinhalt wechseln
Teddy Ruxpin Arm Button Replacement
Was du brauchst
  1. Teddy Ruxpin Arm Button Replacement, Battery: Schritt 1, Bild 1 von 2 Teddy Ruxpin Arm Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Arm Button Replacement: Schritt 2, Bild 1 von 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Arm Button Replacement: Schritt 3, Bild 1 von 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Arm Button Replacement, Arms: Schritt 4, Bild 1 von 3 Teddy Ruxpin Arm Button Replacement, Arms: Schritt 4, Bild 2 von 3 Teddy Ruxpin Arm Button Replacement, Arms: Schritt 4, Bild 3 von 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Arm Button Replacement: Schritt 5, Bild 1 von 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Arm Button Replacement: Schritt 6, Bild 1 von 3 Teddy Ruxpin Arm Button Replacement: Schritt 6, Bild 2 von 3 Teddy Ruxpin Arm Button Replacement: Schritt 6, Bild 3 von 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Arm Button Replacement: Schritt 7, Bild 1 von 2 Teddy Ruxpin Arm Button Replacement: Schritt 7, Bild 2 von 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Arm Button Replacement: Schritt 8, Bild 1 von 2 Teddy Ruxpin Arm Button Replacement: Schritt 8, Bild 2 von 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Arm Button Replacement: Schritt 9, Bild 1 von 1
    • Unplug the arms from the main body.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Lauren
226 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S18-G5, White Winter 2020 Mitglied von Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - Antwort
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - Antwort
So has anyone figured out how to replace the button?
knrobinson83 - Antwort
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
Eliza Zollicoffer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 991
