Einleitung
Need to access the electronics of inside of your Teddy Ruxpin? This guide will show you how to remove the interior housing cover of the Teddy Ruxpin model #17262DS giving you access to the electronics inside that you might need to replace. Not only does this guide involve damaging the Teddy’s fur, it will also require you to remove the fur entirely. You will need to use a Phillips #1 screwdriver head, and scissors.
Was du brauchst
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
Remove the interior of the doll.
Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Eine weitere Person hat diese Anleitung absolviert.
