Was du brauchst
Completely power down device.
Remove stylus, sd card (if you have one), and case adaptor from device.
Insert thin tool (I used a knife) into the seam around the edges of the device and gently pry back cover off. It is held on only by clips but will require carefulness to avoid damage.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
