Einleitung
This guide is to replace your Tektro Aires Disc Brakes pad, the guide will show you step by step with instructions and pictures. you may need to replace your brake pads due to wear or damage. In order to complete the replacement you will need to use the tools mentioned (1x5 mm Hex Key, 1 x Large needle nose pliers) on the steps that they're needed for. It is recommended to wear gloves as skin oils will affect the break pad's performance.(If not be careful not to touch the break pads when reinstalling)
Was du brauchst
Place the spring on the new Tektro Disc Brake Pad as shown.
The other brake pad will go on the spring opposite the first brake pad.
- The steps for the front wheel are the same as the back wheel.
- Follow steps in reverse for reassembly.
2 weitere Personen haben diese Anleitung absolviert.
