Was du brauchst
Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
Continue to work your way around the phone counterclockwise until you can pull the back cover off.
Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
