Zum Hauptinhalt wechseln
Tengda S5 Plus Speakers Replacement
Was du brauchst
  1. Tengda S5 Plus Speakers Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the phone screen-side down.
  2. Tengda S5 Plus Speakers Replacement: Schritt 2, Bild 1 von 2 Tengda S5 Plus Speakers Replacement: Schritt 2, Bild 2 von 2
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Speakers Replacement, Speakers: Schritt 3, Bild 1 von 1
    • Using either your thumb or an iFixit opening tool, remove the battery and set it aside.
  4. Tengda S5 Plus Speakers Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
  5. Tengda S5 Plus Speakers Replacement: Schritt 5, Bild 1 von 2 Tengda S5 Plus Speakers Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Speakers Replacement: Schritt 6, Bild 1 von 2 Tengda S5 Plus Speakers Replacement: Schritt 6, Bild 2 von 2
    • Using an iFixit opening tool, remove the speakers.
    • Do not be afraid to use a little force. The speakers are glued onto the phone, not wired.
Abschluss
Andrew Lam
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-9, Amido Spring 2015 Mitglied von Cal Poly, Team 14-9, Amido Spring 2015
CPSU-AMIDO-S15S14G9
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 369
