Einleitung
Use this guide to assist in replacing the battery in a Tesla Model S keyless fob remote. A Tesla key fob assists the user in accessing their Tesla vehicle from a distance. The key fob also allows the user to perform various remote functions such as door unlock/lock as well as a front and rear trunk hatch open button. Due to everyday use, the fob may begin to operate intermittently over time. This may be a result of the battery needing to be replaced. There are no special skills or tools required to complete this task.
Was du brauchst
Insert the flat end of a spudger into the notch, and gently pry the key fob open along the seam.
Separate the cover from the key fob.
Insert the flat end of a spudger into the entry point at the top of the key fob.
Lightly push the spudger under the battery.
Remove the battery from the key fob.
With your fingers, insert a new CR2032 battery into the opening.
Push the battery with your thumb to lock it into place.
To close the key fob, enter the wider side of the cover into the opening in the middle of the key fob.
You should see the end of the cover a little popped out.
With your thumb and pointer finger push together the cover and the key fob to allow for the key fob to be securely closed.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Really, that tip was helpful, the last time i my model s tesla key fob's battery was dead, I order another on amazon, and some tips online here on tesla key fob programming. At first, I was a little bit skeptical given that I have not done such a thing before on my tesla. However, the process was really simple and the guide on the site was helpful.
