Zum Hauptinhalt wechseln
Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement
Was du brauchst
  1. Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: Schritt 1, Bild 1 von 3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: Schritt 1, Bild 2 von 3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: Schritt 1, Bild 3 von 3
    • Unlatch hooks all around the left casing (three on each side)
    • Carefully lift cover, fold it over and tape it to the head piece to get it out of the way. The NFC antenna is glued to the cover. Two wires connect it to the bundle.
    • Pry battery out w/ a spatula. You'll gain access to the speaker cables and can unsolder and replace the battery, if needed.
    • In case you need to get to the speaker, see https://de.ifixit.com/Anleitung/Teufel+A... for details.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
andre
1.701 Reputation
4 Anleitungen geschrieben
Ein Kommentar
Thank you very much for this guide!
Patch - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 16
Insgesamt: 404
