Zum Hauptinhalt wechseln
Texas Instruments TI BA II PLUS Battery Replacement
Was du brauchst
  1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Texas Instruments TI BA II PLUS  Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Switch off the calculator by pressing the button at the top right corner.
  2. Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 2, Bild 1 von 1
    • Turn over the calculator so the backside of the calculator is facing upwards.
    • Remove the four 2mm Phillips #00 screws from the bottom cover.
  3. Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 3, Bild 1 von 1
    • Open a small gap at the bottom of the calculator, using a spudger or your fingers.
    • Move your thumb from the bottom edge to the top.
    • Be gentle when separating the cases to avoid breaking the clips.
  4. Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 4, Bild 1 von 3 Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 4, Bild 2 von 3 Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to remove the battery from the cage at the bottom of the motherboard.
  5. Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 5, Bild 1 von 1
    • Replace the battery with the new CR2032 Lithium Battery in the battery cage.
  6. Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 6, Bild 1 von 2 Texas Instruments TI BA II PLUS  Battery Replacement: Schritt 6, Bild 2 von 2
    • Reattach the calculator cases, beginning from the top edge.
    • Use the Phillips #00 screwdriver to replace the 2.00 mm screws.
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
Peipei Yu
241 Reputation
1 Anleitung geschrieben
York University, Team S2-G30, O'Regan Winter 2021 Mitglied von York University, Team S2-G30, O'Regan Winter 2021
YORK-O'REGAN-W21S2G30
1 Mitglied
2 Anleitungen geschrieben
2 Kommentare
It's amazing that this calculator can break. I am an accountant student in college and despite modern technologies and the rather powerful functionality of modern smartphones, I like to use just such a calculator for financial calculations.
AlGorFun - Antwort
Great guide, thanks! The spudger was necessary for me to separate the case, as I couldn’t separate it with my fingers alone.
Jonathan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 129
Letzte 30 Tage: 550
Insgesamt: 23,602
