Einleitung
This guide demonstrates and describes proper removal and replacement of the back casing. It is needed to access other parts for repair or replacement.
Was du brauchst
Locate battery cover on the back of the case.
Slide battery cover to the right reveal the batteries.
Remove battery cover.
Slide the red lock down.
Slide the metal tab to the right of the top battery.
Remove the 3-Volt Lithium Coin Cell Battery.
Slide the red lock up.
Slide the metal tab to the right of the bottom battery.
Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
Unscrew four 7.15 mm screws from back casing.
Using the blue plastic opener tool along the seam of the case, pry off front casing.
