Zum Hauptinhalt wechseln
Texas Instruments TI-83 Plus Backup Battery Replacement
Was du brauchst
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: Schritt 1, Bild 1 von 2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: Schritt 1, Bild 2 von 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
    Frag FixBot
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
    Frag FixBot
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: Schritt 3, Bild 1 von 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    Frag FixBot
Abschluss
Cal Poly, Team 18-37, Regan Fall 2012 Mitglied von Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Mitglieder
5 Anleitungen geschrieben
2 Kommentare zur Anleitung
Will this wipe the memory?
John Osborne - Antwort Teilen
Yes I found one and have been trying to get it together for a high schooler I had one when I took trig in college and it was very helpful
Jack Irvin - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 108
Insgesamt: 23,921
