Zum Hauptinhalt wechseln
Texas Instruments TI-83 Plus Individual Keys Replacement
Was du brauchst
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: Schritt 1, Bild 1 von 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: Schritt 1, Bild 2 von 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 2, Bild 1 von 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 3, Bild 1 von 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: Schritt 4, Bild 1 von 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 5, Bild 1 von 2 Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 5, Bild 2 von 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: Schritt 6, Bild 1 von 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: Schritt 6, Bild 2 von 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 7, Bild 1 von 2 Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: Schritt 8, Bild 1 von 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: Schritt 8, Bild 2 von 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: Schritt 9, Bild 1 von 1
    • Clean the contacts on the keyboard with a soft cloth.
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: Schritt 10, Bild 1 von 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: Schritt 10, Bild 2 von 2
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jared
151 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-37, Regan Fall 2012 Mitglied von Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 4,664
