Einleitung
In this repair guide, we will be showing you how to determine whether or not you will need to buy a new foot pedal replacement for you drum set . Be prepared to unscrew some of the screws on the foot pedal and make sure to keep those screws somewhere safe as you continue following the steps. Keep in mind that you may need to acquire a new foot pedal if need be.
Was du brauchst
Remove the two Phillips size J0 screws holding the cover plate on the top of the foot pedal.
If this small sensor is broken, it is time to buy a new foot pedal and replace the broken one.
2 Kommentare
How can I connect my rockband drums to my laptop to make it a personal drum pad?
Email me
Abrajoe11@yahoo.com
Thanks
