Zum Hauptinhalt wechseln
The Beatles Rock Band Hofner Bass Back Plate Replacement
Was du brauchst
  1. The Beatles Rock Band Hofner Bass Back Plate Replacement, Back Plate: Schritt 1, Bild 1 von 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Back Plate Replacement: Schritt 2, Bild 1 von 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Back Plate Replacement: Schritt 3, Bild 1 von 2 The Beatles Rock Band Hofner Bass Back Plate Replacement: Schritt 3, Bild 2 von 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
Abschluss
Jacob
601 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 8-4, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 812
