Einleitung
Do you know the way to keep the thickness of iPhone XR is as same as that of the original after changing a new back glass? Maybe you know how to replace the back glass, but do not know how to make the thickness be the same as the original.
Was du brauchst
Einführungsvideo
We put the whole phone into Blue Light Laser Separation Machine to laser the back glass so that we can easily remove the back glass, by then.
The master will use a blade and a sharp knife to remove the back glass.
The back glass is very easy to be separated after doing laser. That’s why we choose to use blue light laser machine to separate the back glass. It can reduce the tear down difficulty of iPhone.
This is the final effect after taking apart the back glass.
Before cleaning black things. We should clean the glass around the edge with a small tool.
Once done, we continue to clean black things with clean cloth and alcohol.
Now, we’ve already clean up black things and finally there are many glue remaining. These glues are really useful because they are the key point to keep the same thickness as the original one.
Here we add new glue around the phone body and blank place without glue.
You can see the final looking after adding glue in below picture.
Stick a new back glass on the phone and use four clamping tool to hold the pressure.
The total replacement has been finished now. This is the final effect which the phone looks like as perfect as the original one.
If you are looking for the best way to take apart the back glass of cellphone and change it, you can come to see whether this way is suitable for you or not.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
