Zum Hauptinhalt wechseln
The Claw "Claw" Replacement
Was du brauchst
  1. The Claw  "Claw" Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw  "Claw" Replacement: Schritt 2, Bild 1 von 1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw  "Claw" Replacement: Schritt 3, Bild 1 von 1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw  "Claw" Replacement: Schritt 4, Bild 1 von 1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw  "Claw" Replacement: Schritt 5, Bild 1 von 1
    • Remove the top cover of The Claw machine.
  6. The Claw  "Claw" Replacement: Schritt 6, Bild 1 von 2 The Claw  "Claw" Replacement: Schritt 6, Bild 2 von 2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw  "Claw" Replacement: Schritt 7, Bild 1 von 1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw  "Claw" Replacement, Claw: Schritt 8, Bild 1 von 1
    • Once you have removed the top cover of the claw you can easily access the claw and you will see that the claw is attached by two small chains.
    • Locate the small rings that attach the chain to the plastic claw.
  9. The Claw  "Claw" Replacement: Schritt 9, Bild 1 von 1
    • Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
    • Replace the claw one ring at a time. The chain needs to be attached to the new claw in the same configuration. One side of the chain opens the claw and the other side is just a hanging support.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alain Pierre
1.188 Reputation
9 Anleitungen geschrieben
UMass Dartmouth, Team 4-8, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
3 Mitglieder
18 Anleitungen geschrieben
6 Kommentare
Where do I buy a new grabber thing
Oliver Chew - Antwort
The 1st joystick that moves the claw forward and back doesn’t work.
Michelle Bianchini - Antwort
What if the chain won't go down as it deep as it used to be?
Mira DIP - Antwort
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
Greg Sturges - Antwort
My chain fell off and I dont know how to fix
Kathellyn Da silva - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 77
Insgesamt: 8,785
