Einleitung
This guide will teach you how to properly replace the batteries in your Claw Machine. If you are experiencing any power related issues with your device follows these steps.
Was du brauchst
Locate the battery compartment door on the bottom cover of The Claw.
Loosen the screw from the battery compartment door with your phillips head screwdriver.
Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
