Einleitung
After repeated use of the claw machine, eventually you will run out of toys or candy to grab. In order to complete this task you will need to remove the top cover of your claw machine. Follow this user friendly guide to assist you with this task.
Was du brauchst
Place The Claw machine in the up-right position with the control knobs facing you.
Turn The Claw machine upside-down placing the top cover on the surface of your work area.
Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
