Zum Hauptinhalt wechseln
The right way to remove HTC 10 screen
Was du brauchst
Videoanleitungen
Abschluss
1. It is not possible to open HTC 10 lcd with spudger, knife, card;
2. We opened it under the help of suction cup;
3. The screen edges of HTC 10 cools down very quickly because of the metal back housing, so we should heat up the edges for several time and each time heat up for a quite long time.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Witrigs
69.493 Reputation
378 Anleitungen geschrieben
6 Kommentare
Hi,
is there any tutorial for separating the digitizer from screen?
My screen is fine but the digitizer is broken.
Thanks for your help
Mahdi Mohammadi - Antwort
What is your point showing us a card doesn't work..yet it is a useful tool in the end. Why don't you save us all some viewing time and show video showing just how to remove the screen?
Drew DeGraff - Antwort
Took me 30 seconds to open with a heat plate and Exacto 17.
Max Dailey - Antwort
What temp and time did you use? face up or down?
David Fear -
Thank you for this usefull video.
Easy Repair - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 15,893
