Einleitung
This guide will provide step by step instructions to show how to fix a button that is no longer clicking properly.
Was du brauchst
Remove the plastic cover and pack of weights.
Remove the two 1.0 mm foam covers with tweezers.
Peel away the plastic screw cover with tweezers.
Remove the four 1.0 mm screws with a Ph #1 screwdriver.
Gently remove the top of the mouse.
Flip the cover of the mouse over.
Fold a piece of tape over on itself. This should make both sides sticky.
Cover both buttons with tape to increase the surface area of each click.
