Zum Hauptinhalt wechseln
ThinkPad Edge E31 Underside Disassembly
Was du brauchst
  1. ThinkPad Edge E31 Underside Disassembly, Battery: Schritt 1, Bild 1 von 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Underside Disassembly: Schritt 2, Bild 1 von 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Underside Disassembly, ThinkPad Edge E31 Underside Disassembly: Schritt 3, Bild 1 von 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
Abschluss
Riley
601 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S6-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 317
