Einleitung
This disassembly guide is to remove the back of the laptop to expose commonly replaced and upgraded components of the laptop.
Was du brauchst
There are two two locks for the battery, one on the left and one on the right.
Slide the left lock to the left.
Slide and hold the right battery lock to the right.
While holding the right battery lock, slide the battery up to remove it from the laptop.
Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
