Zum Hauptinhalt wechseln
ThinkPad X1 Carbon Battery Replacement
Was du brauchst
  1. ThinkPad X1 Carbon Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew the seven screws located on the back of the device
  2. ThinkPad X1 Carbon Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Battery Replacement: Schritt 3, Bild 1 von 1
    • Flip the device over and open it to lift the keyboard tray from the body of the device .
  4. ThinkPad X1 Carbon Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently release the ribbon cable attached to the keyboard.
    • Gently Place keyboard tray to side.
  5. ThinkPad X1 Carbon Battery Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the 4 screws holding the battery in place.
  6. ThinkPad X1 Carbon Battery Replacement: Schritt 6, Bild 1 von 1
    • Unlock and remove the ribbon cable running over the top of the battery.
  7. ThinkPad X1 Carbon Battery Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the battery connection from the motherboard .
Abschluss
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 76
Insgesamt: 606
