Zum Hauptinhalt wechseln
Einleitung
You will learn how to open the ThinkPad X1 Carbon and replace the CPU Fan
Ersatzteile
Keine Ersatzteile angegeben.
  1. Loosen the seven cover screws. They will not come out.
    • Loosen the seven cover screws. They will not come out.
  2. Use spudger to pop loose cover and slide off.
    • Use spudger to pop loose cover and slide off.
  3. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  4. Only use plastic to remove battery connector
    • Only use plastic to remove battery connector
    • Gently remove battery connector bu pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, and not easy to re-connect.
  5. Use your spudger to open the connector in the direction of the arrow.  Carefully remove the ribbon cable
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
  6. Loosen screws and pull fan up and out of the case.
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Mike
1.449 Reputation
5 Anleitungen geschrieben
iReconstruction Mitglied von iReconstruction
Business
1 Mitglied
6 Anleitungen geschrieben
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 24
Letzte 30 Tage: 114
Insgesamt: 6,229
