Zum Hauptinhalt wechseln
ThinkPad X1 Carbon Push Button Controls Replacement
Was du brauchst
  1. ThinkPad X1 Carbon Push Button Controls Replacement, Push Button Controls: Schritt 1, Bild 1 von 1
    • Unscrew the seven screws located on the back of the device.
  2. ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 2, Bild 1 von 1
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 3, Bild 1 von 1
    • Flip the device over and open it to lift the keyboard tray from the body of the device.
  4. ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 4, Bild 1 von 1
    • Use the Plastic Spudger to gently release the ribbon cable attached to the keyboard.
    • Place device to side.
  5. ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 5, Bild 1 von 3 ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 5, Bild 2 von 3 ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 5, Bild 3 von 3
    • Unlock and remove the 3 ribbon cables along the top of the keyboard tray.
  6. ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 6, Bild 1 von 1
    • Locate and unscrew the 3 silver screws.
  7. ThinkPad X1 Carbon Push Button Controls Replacement: Schritt 7, Bild 1 von 1
    • Gently wiggle and lift the Push Button board from the keyboard tray.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 48
Insgesamt: 1,937
